ABS Light just started coming on every now and then.
Old Aug 12, 2005 | 12:04 PM
sghokie's Avatar
Default ABS Light just started coming on every now and then.
about 2000 miles ago my abs light came on once, I drove it 1500 miles and didnt have it come on at all. Now in the last 300 miles it has come on 3 times. Any ideas where to start?
Old Aug 12, 2005 | 10:22 PM
Default RE: ABS Light just started coming on every now and then.
The ABS module is most likely bad.
But you should have the codes pulled to see.
Old Aug 14, 2005 | 06:43 PM
knight rider's Avatar
check your individual wire connections to the abs modules on each wheel. Mine had been severed and I just had to reconnect w. new module. Never hurts to look. A lot cheaper than rebuild on ABS module. Most likely the module is bad. Common problem on these cars.
Old Aug 15, 2005 | 02:45 AM
pistolero45e's Avatar
ABS controller has some loosed connection on the circuit board. I do not know how to open the module. I can be repaired at about $75. I paid $150 to get mine fix by Mr. Rocha in Southhern CA. I saw another ad last time for $75 I just can't remember where. Try searching. Good Luck!
JamesO84
Feb 28, 2015 05:36 PM
dwdog
1998-2000 model year V70
Apr 16, 2013 06:46 PM
dwdog
Jan 19, 2013 05:00 PM
autoxray
Nov 12, 2009 08:37 AM
