AC Fan works great but dies on hot
Old Apr 14, 2011 | 08:49 AM
Squiggy's Avatar
Default AC Fan works great but dies on hot
I did try searching for an answer before posting but came up snake eyes.
My AC fan seems to work great. I can run AC cold all day long. But when I turn on the heat my fan will die and only start again if I shut off the motor and fire it back up.
Any ponderings on my conundrum? If not I shall have to to consult the bones.
Old Apr 14, 2011 | 10:36 AM
My fan was dying on me and would slow to a stop sometimes. Not sure what the situation was because it was at least 18 months ago. I took the motor out and lubed it with some lithium grease or something like that, it was recommended. It has worked fine ever since.
Old Apr 14, 2011 | 12:02 PM
MattyXXL's Avatar
Sounds like the motor bearing are starting to go.
If you pull out the glove box , see if next time it doesnt spin tap the back of the motor with hammer or driver handle to see if that frees it up.
Cleaning it and Lubing it will defiantly prolong its life but take a look at the brushes, where mine were touching their contacts it was all grooved up, I sanded the contact down a little so they made a better contact. That only worked for about 3 weeks... The brushes were gone when I pulled it next..
Old Apr 14, 2011 | 08:19 PM
Squiggy's Avatar
Thanks guys. I must be confused because I thought the same fan that blows cold air from the AC also blows hot air from the heater. It sounds like there are 2 different fans?
My deal is that the fan that blows cold air from the AC never dies. But when I have the hot air on the heat will die if I turn it up too much.
Old Apr 14, 2011 | 08:29 PM
MattyXXL's Avatar
I totally misunderstood...My mistake.
Copy.. It may be the motor resistor getting too hot.. maybe?
when it shuts down and you flip it to A/C will it turn on rite away?
Old Apr 14, 2011 | 08:37 PM
Squiggy's Avatar
If my heat shuts off but then I flip it to cold AC (without restarting the car first) will the AC work? Hmm. Good question. I'll have to test that...
blackbrick
2001-2013 model year V70
Aug 14, 2014 07:11 PM
kbottawa
Jul 21, 2010 08:28 PM
beardo265
Sep 27, 2007 09:24 AM
mooser
Jun 16, 2006 12:09 AM
