AC works great but....
Old Jul 15, 2010 | 02:56 PM
kbottawa's Avatar
Default AC works great but....
I have a volvo s70 - it has 400K but I couldn't quite on this car.
AC works greate for 10 - 15 min then compressor goes off (I check the power wire to compressor and it gives 0 voltage at that time compressor goes off). I have to keep the AC OFF for 5 - 10 min before I can use them again. What could be the problem ? Is it pressure switch ? How do I test pressure switch is good or bad ? Can I change pressure switch by myself with out put freon agian ? Where is pressure switch located ? I know my car is not low in freon.
When I connected a 12 V wire directly to compressor and it seems to work find. Is there any danger by doing this ? I can have a switch to control - can I do that ?
Thanks in advance.
Old Jul 17, 2010 | 07:26 AM
There is a relay in the main fuse box under the hood the relay may be the issue.
Old Jul 21, 2010 | 10:00 AM
xudustin's Avatar
I am having a similar situation with my S70 Turbo which is not very much appreciated here in the South during the Summer. Have you been able to rectify the issue? I will go from nice cool air to vent after 1-15 minutes as well and then I will turn the AC button on and off while driving and sometimes it will kick back on. I want to get a little more education on this prior to taking it in so I don't get hammered with extra costs I don't need to spend.
Old Jul 21, 2010 | 08:28 PM
viperbite's Avatar
let a tiny bit of refrigerant out of the system and see if it fixes it...
just like 1 to 2psi
blackbrick
2001-2013 model year V70
Aug 14, 2014 07:11 PM
Squiggy
Apr 14, 2011 08:37 PM
floryed
Jan 26, 2008 07:06 PM
mooser
Jun 16, 2006 12:09 AM
