AC works most of the time
Old Jul 10, 2007 | 11:26 AM
Dainos's Avatar
Default AC works most of the time
My AC stops cooling sometimes.It does not need to be recharged(I think).Any possibly explanations?Is there a relay for the AC or something I can replace?
Old Jul 11, 2007 | 01:56 AM
JPN's Avatar
JPN
Default RE: AC works most of the time
Hello,
I would make sure that the system pressure is not dropping. The original evaporator on 850 is guaranteed to fail so it may be leaking from there. If the evaporator is OK, the compressor may have to be re-shimmed. Here's an instruction:
https://volvoforums.com/m_34431/tm.htm
If the compressor is turning on & off intermittently, I suspect the evaporator is leaking. You could either buy an aftermarket recharge kit that has a pressure gage (approx $30-$40), or have an auto AC shop do a leak test.
I hope this gets you started.
JPN
EDIT: The specified AC system pressure for 850 is 25-33PSI.
[IMG]local://upfiles/6892/058BD4A989F14ED19ED58D889A0250A3.jpg[/IMG]
magic blue s60r
Apr 7, 2015 03:08 PM
blackbrick
2001-2013 model year V70
Aug 14, 2014 07:11 PM
VolvoWagonz
May 28, 2014 03:55 PM
TEQUILA
Feb 6, 2010 04:03 PM
