Aftermarket Wheels
Old Dec 20, 2008 | 11:35 AM
raybun's Avatar
Default Aftermarket Wheels
I just purchased a set of mounted tires for my 850 over the internet. The wheels were not drilled for the alignment pin. Does this pin have any other function that to make mounting the wheels easier? The mounting holes on these aftermarket wheels were not countersunk like the stock alloy wheels. I mounted them with the stock lug bolts that have the tapered shoulder to match the countersink in the stock wheels. Do these stock lug bolts need to be changed to something suitable for use with non countersunk wheels? Should I not be using these aftermarket wheels?
Thanks
Ray
Old Dec 20, 2008 | 06:48 PM
bitter356's Avatar
Default RE: Aftermarket Wheels
Been there, pretty frustrating.The pins serve two duties. One to ease wheel installation/removal. The second is to fasten the rotor to the wheel hub assembly.The easy choice is to dremmel the wheel to accept the pin.If you are gun shy on wheel modification, you will have to countersink the rotor to accept a taper screw to fasten the rotor to the hub. Hope this helps!
thrbrdrider
Nov 26, 2013 04:04 PM
Hedgetrimmer
May 31, 2013 01:08 PM
MChanceS40
Dec 23, 2012 10:11 AM
raybun
Dec 20, 2008 07:58 AM
freudslip
Dec 3, 2004 03:01 AM
