aftermarket wheels
Old Dec 19, 2008 | 03:48 PM
raybun's Avatar
Default aftermarket wheels
I just purchased a set of mounted tires over the internet. The wheels were not drilled for the alignment pins. I unscrewed the pins and mounted the wheels anyway. Do these pins serve a function or are they there just to make mounting the wheels easier? The lug holes on the new wheels were not countersunk like the stock alloy wheels on my 850. I needed to mount these snow tires immediatly so the beveled shoulder lug bolts that were on the old wheels were used. Do I need to replace the lug bolts ? Should I even be using these aftermarket wheels?
Thanks
Old Dec 19, 2008 | 06:27 PM
litehwk356's Avatar
Default RE: aftermarket wheels
i dont think it will cause much of an issue, i believe that the pin is there to serve two purposes:
1: keep the disc on when the whell is off, and
2: help you to line up the rim.
Old Dec 20, 2008 | 07:58 AM
JimKW's Avatar
The pin being removed should not cause a problem at all. I would find lug nuts that are made to fit the wheels you have though. If the lug nuts do not fit the hole in the wheel right I have seen cases where the holes will eventually wear bigger and bigger and the wheel will get lose and come off over the lugs.
thrbrdrider
Nov 26, 2013 04:04 PM
Hedgetrimmer
May 31, 2013 01:08 PM
MChanceS40
Dec 23, 2012 10:11 AM
raybun
Dec 20, 2008 06:48 PM
freudslip
Dec 3, 2004 03:01 AM
