Air Pump Running and Running
Old Jul 11, 2010 | 02:00 PM
ridejoeride's Avatar
Default Air Pump Running and Running
The air pump motor will run at will hours after the engine is turned off, sometimes draining the battery. Is there a relay switch that needs to be changed or cleaned?
Old Jul 11, 2010 | 05:52 PM
There should be a relay under the front of the car by the pump.
Old Jul 12, 2010 | 08:03 PM
fcpgroton's Avatar
Former Sponsor
Take it out and give it a good cleaning and that should make it work again. It is probably stuck in the on position.
volvorecycle
Oct 10, 2013 04:30 PM
turboxr
Dec 17, 2011 12:35 AM
vjaneczko
May 3, 2010 07:35 PM
katiejoyful
Dec 12, 2007 04:49 PM
