Alignment questions
Old Sep 5, 2013 | 11:19 PM
Chrispy_T's Avatar
Default Alignment questions
I have a 95 850 Turbo. I've noticed that, when I cut the wheel, the camber on the outside tire is POSITIVE while the inside is negative. It's like the caster goes from positive to negative based on where the wheels are turned. If this is the case, wouldn't it be bad for handling and really bad on tires? It would explain some things.
Old Sep 6, 2013 | 05:23 PM
Time to inspect the steering and suspension components for play and it would make more sense if you posted pictures of your concern.
outdoor7or24
Nov 8, 2012 11:44 AM
Phil 850
Jul 25, 2012 10:01 PM
MK1
Nov 30, 2005 10:45 PM
ludeless
Nov 23, 2005 08:14 PM
Osmenthe
Jul 9, 2005 01:36 PM
