Alternator
#22
hey said the car was not that far out of spec in the front but the back is way out but there is no adjustment for it because it is a solid axle.
If you let go of the steering wheel the car will be in the ditch in less than 100ft.
It is almost undrivable in the snow, it was not this way before the struts so I have no idea what happened, the shop didnt even touch the back.
If it is pulling, the front alignment is out.
#24
Hold on. My car had a bad rear suspension. Something was wrong such that there was a lot of negative camber. Camber is not adjustable. Rather than try a whole bunch of things to no avail, I found a good rear suspension from a donor car and had my mechanic install it. After that, everything was back to normal. I had a front end pull, and my steering wheel was off-centre when driving straight. Once I replaced the rear the car tracked perfectly, steering wheel dead-on straight. If you have a pull, and the front alignment is good, the rear CAN be the culprit. If things are bent such that it's turning the back of the car slightly, you'll need something up front to compensate.
#26
#27
That way as you replace parts or nail potholes the size of a '68 Beatle (I'm in Minnesota and we grow 'um big up here !!) you can take it back and it's free.
I have a hard time with the roughly 180 dollar price but it's nice to know you wouldn't have to pay for it again.
#28
You know, I thought better of saying that about not trusting chain shops after I said it. I have personally had mixed experiences with both chain and local shops.
It's tough to beat the convenient hours, and the lifetime alignment is nice. I think the important part is to find a good shop, hopefully one that doesn't turn over all the techs every three months.
#29
They are directional tires and I rotated them front to back, no change.
They have maybe 20,000 miles on them.
#30
They have 4 techs, the owner and co-owner are 2 of them, they have 3 bays, they dont drive BMW's or Cadillac's either.
They do not do alignments though, so I did take it to Goodyear for that.
And the steering wheel is straight while going straight.
I cant do anything until the weekend, but I am going to take it back to Goodyear and have them double check.
#31
#32
#33
#34
