Another noise question
Old Oct 3, 2014 | 08:01 PM
Phil 850's Avatar
Default Another noise question
I am getting a noise from the center of the dash or even more over on the drivers side that sounds like a small motor with a bad bushing. it starts around 45 MPH but below that it doesn't happen. If I speed up to 45 it comes on and when I slow down it goes away. Any one have any ideas of what is located in that area? If the car had the old style mechanical speedometer I would look at that.
Old Oct 6, 2014 | 12:23 AM
Phil 850's Avatar
OK, this does seem to be speed related. If I speed up until it starts and then shift into neutral the sound is still there until the car slows below 45. Are there repairable parts of the speedometer such as gears that are replaceable?
Old Oct 6, 2014 | 07:38 AM
boxpin's Avatar
Are you sure its not wind noise from the trim piece that goes along the top of the windshield? Even the slightest lift will bring in a buzzing noise.
Old Oct 6, 2014 | 03:22 PM
Phil 850's Avatar
I think you got it. That trim is loose above the drivers side. Any suggestions on the best stuff to stick it back down?
Old Oct 7, 2014 | 10:38 AM
boxpin's Avatar
Take it by a glass shop and see if they will tack it down for you. Its a simple thing for them to do and good customer service.
donf
Jul 4, 2012 08:47 PM
96960Chris
Jun 25, 2011 04:49 PM
mrl
Aug 9, 2009 08:07 PM
NetAvatar
Feb 28, 2008 05:43 PM
cruzer 99
Jul 7, 2006 09:34 PM
