Any ideas what the problem is?
Old Oct 14, 2007 | 09:25 PM
86gix's Avatar
Default Any ideas what the problem is?
http://denver.craigslist.org/car/448837173.html
Anyone know what causes this, and how expensive/difficult it is to fix?
Thanks,
Jeff
Old Oct 14, 2007 | 10:15 PM
tripleb's Avatar
Default RE: Any ideas what the problem is?
You should try e-mailing the seller to see if they can give you some info about the problem then we will have more info to work with.
Ask if the check engine light has been on, and if any trouble codes are stored.
Ask how long the problem has been occuring, and what are the temps that they are talking about. It can get pretty cold in Denver, but not this early in the Fall.
Did they make have any servicing or make any repairs before the problem started?
I live in California where we don't see very low temps, so maybe someone from a colder area might have a good idea as to what could cause this, but with a little more info I might have some ideas.
B
Old Oct 15, 2007 | 08:11 AM
jmana's Avatar
Are Volvos worth more in Denver? The seller says it's priced way below market value, but $2,000 for a 93 with 200,000 miles seems kind of high, even if it was running perfectly!
Old Oct 15, 2007 | 09:03 AM
Systek's Avatar
I had the same problem with a 97 960 and could never figure it out. In freezing temperatures, it would not turn on. I gave up on it...
Old Oct 15, 2007 | 09:08 AM
86gix's Avatar
I dont know about values in Denver. Actually I have not been watching Volvos in general until this weekend. Sold my Jeep unexpectedly Friday and am carless now. Anyway if you go to Kelley Bluebook, the asking prices for most Volvos here are on the low end. This one I should probably just stay away from then?
Thanks,
Jeff
Old Oct 15, 2007 | 06:24 PM
It might be a bad coolant temp sensor.
Old Oct 15, 2007 | 06:34 PM
JimKW's Avatar
You can't expect much for $2,000.
04arghh
Aug 23, 2007 02:44 PM
JVC
Jul 2, 2007 03:14 PM
jonnycd
Jun 12, 2007 06:12 PM
JasonCase
Mar 11, 2007 01:46 PM
seattlevolvoguy
Jan 1, 2006 05:31 PM
