Anyone wanna play "name that connector"?
Old Oct 24, 2013 | 09:49 PM
awfulwaffle's Avatar
Default Anyone wanna play "name that connector"?
Taking care of some odds and ends while my cylinder head is at the machine shop, and I've discovered a plug hanging down by the front of my motor that doesn't appear to have been connected to anything for quite a while:
Here is a wider shot with the connector circled in red:
Would anyone be kind enough to point me in the direction of what it may be? It's very dirty so I assume it's been unplugged for quite a while, and I'd like to get it cleaned up and back in its home.
Old Oct 24, 2013 | 09:50 PM
97black850's Avatar
not for the knock sensor is it?
Old Oct 24, 2013 | 10:27 PM
Nope, both knock sensors connected.
Old Oct 24, 2013 | 11:20 PM
mudpie's Avatar
In the process of removing engines, on multiple occasions I've come across several connectors in various places that aren't connected to anything. I can only assume they're either diagnostic ports, or plugs for various other engines. I think Volvo uses a wiring harness that's ready for anything, rather then use a different harness for whatever configuration is in each car.
If it's running good, and there's no lights on the dash, roll with it
Old Oct 25, 2013 | 01:21 AM
Brick850's Avatar
On mine it is for the knock sensor. There are two different type of knock sensors you can get. One like the setup you have, where the sensors have the plugs on them individually, and mine has one plug that branches off to two knock sensors and it all one unit.
Old Oct 25, 2013 | 01:50 AM
scutyde's Avatar
what color are the wires?
I have the same engine and needed to rebuild my engine harness after it burned this summer and there were no "extra" connectors in that area which were left not connected...
EDIT: If your car is from 93 or 94 it could be the connector for the oil level sensor. It's the only thing that is located in that area...however Volvo decided from 94 to leave the sensor away presumably because it was unreliable... Wire colors should be Brown-White and Black.
Old Oct 27, 2013 | 11:30 PM
Scutyde, one wire is black, and the other is white/red. I suppose, though, that it could be brown and not red. Thanks!
ajattridge
Jul 17, 2015 09:54 AM
jasstrom
Dec 10, 2013 03:41 PM
bigdaddyrdpjr
Mar 7, 2011 01:44 PM
allanburns
Jul 28, 2010 02:14 AM
850Girl
Mar 12, 2009 01:12 AM
