ARD Orange Tune
Old Nov 1, 2013 | 03:15 PM
BFR's Avatar
BFR
Default ARD Orange Tune
I'm wondering if any of you have run ARD's Orange Tune, which I'm considering for my otherwise stock 1996 850R. I know the company has a good reputation from the search I did but I was unable to find anything discussing the pros (or cons if they exist) of this tune in any detail.
All I basically know about this tune is that it puts the boost at 14 psi and that cam timing is recommended to be set at -1 degrees intake and 0 degrees exhaust for stock cars. That means that on top of the $315.00 cost of the tune, I'll need to spend a few hundred more having a good mechanic who knows these cars pull off the timing belt and reset the cams.
Since the investment would be relatively substantial, it'll be nice to know as much detail as possible, including how beneficial it will be!
Any input will be appreciated. Thanks!
Old Nov 1, 2013 | 07:16 PM
gdog's Avatar
ARD is top notch outfit in Portland OR. I was on the fence also between the orange and green tune. I am definitely an advocate for the green after getting one, but I've only had it for a month or so and still dialing some tweaks in...
Adjusting the cam timing is easy as pie; no pulling of cams. The cam gears are slotted so they allow approx +/- 7 degrees of adjust from the factory (which is really sweet if you think about it). Strongly suggest you spend about $20 on the adjustment tool; ARD has them as does IPD.
BTW: here's an article by Lucky (aka Robert Arnold) about cam timing:
http://www.ardtuning.com/Cam-Timing-Basics_b_13.html
This doc pretty well explains how to use the adj tool (memorize this doc!):
http://www.google.com/url?sa=t&rct=j...PIZlJg&cad=rja
I have tweaked the adj on my cams several times now; can do it in about 5 minutes; no joke.
Old Nov 2, 2013 | 11:25 AM
BFR's Avatar
BFR
Thanks. Very helpful! Any inkling of the performance gains one can expect from an Orange tune + cam adjustment?
Old Nov 2, 2013 | 11:55 AM
Vmax's Avatar
Can you fill me in on how you personally adjust your cam timing?
Old Nov 2, 2013 | 01:36 PM
BFR's Avatar
BFR
A video of the process would be nice. RSPI?
Old Nov 5, 2013 | 11:36 AM
boxpin's Avatar
With a proper cam tool its very easy .
Old Nov 5, 2013 | 12:20 PM
BFR's Avatar
BFR
Thanks. Looks like it. How do I move the cam gears with the belt on them? Do you pull them away or remove the gear and move it?
Old Nov 5, 2013 | 02:19 PM
97black850's Avatar
BFR, i might be mis interpreting you, but the shaft moves when using the tool so the belt does not have be able to move, at least that is how I understand it so Boxpin (or anyone else who has done it) correct me if I'm wrong
Old Nov 5, 2013 | 02:53 PM
BFR's Avatar
BFR
Nope, you're not misinterpreting me, that's what I'm basically asking. My admittedly limited understanding was that the cams were directly bolted to their gears. But if they can move while the gear stays fixed, that would make adjustment easy. I suspect that is the case too but I want to confirm before I yank this thing apart. Thanks!
Old Nov 6, 2013 | 03:40 PM
mfagus's Avatar
BFR, i sent you a note. I have ARD Orange in my 850 Turbo wagon. Feel free to ask any questions you would like.
Mark
RightLeft
Jul 30, 2013 12:14 PM
Ryant5
Jul 27, 2013 09:10 AM
eriknorcal
Jul 20, 2013 02:33 AM
Turkey_Sandwich
Oct 22, 2012 10:17 PM
MattyXXL
Oct 1, 2011 04:06 PM
