Automatic Transmission having a hard time shifting out of first
Old Sep 13, 2008 | 12:49 PM
  #21
Default RE: Automatic Transmission having a hard time shifting out of first
I will look it over thanks good info.
Old Sep 14, 2008 | 12:54 AM
  #22
Maxbaby's Avatar
Well done! I would love to get a look at the "troubleshooting and overhaul" guide listed for $115. I've bookmarked that site for futurereference
Old Sep 15, 2008 | 09:14 AM
  #23
wheelsup's Avatar
Dont spend the $115 yet!
I think this is what they are selling.
Right click save target as (PDF):
Manual for AW50-42LE
Its for the 95 but I would think they are all similar?
It seems Volvo doesnt want you to overhaul the transmission (there is a note at the beginning). They only want you to R&R it. Figures. So no overhaul information is available from Volvo. Probably why they cant be rebuilt successfully.
Old Sep 15, 2008 | 05:00 PM
  #24
Someone sells a kit somewhere.
Toyota also uses these tranny's.
Old Sep 15, 2008 | 10:42 PM
  #25
1996850turbo's Avatar
FCP Groton sells the solenoids. I think they can be done with the tranny in the car. BEFORE doing anything drastic try flushing the fluid and adding the Lucas. Also, my sister in-laws 95 turbo did something similar a few times, she also had the "flashing up arrow" on other occasions so I replaced the PNP switch. ALL the problems went away. I took apart her old switch just to see what the deal is with these and I think it is possible that an intermittant contact inside could cause issues that might not trigger the arrow or a code. Also check the mode switch, make sure it is functioning properly. In addition make sure the UP arrow lights up in first gear.
Incursus
Mar 16, 2015 08:19 PM
TLove
Mar 31, 2014 09:05 AM
mrmanskye
Jul 28, 2013 05:51 AM
scotcha
Mar 11, 2008 11:45 AM
