BBS Wheel Compatability Question
Old Dec 6, 2016 | 04:47 PM
Luke Woessner's Avatar
Default BBS Wheel Compatability Question
https://volvoforums.com/forum/attach...1&d=1481064066
Found these 15x7 offset 36 BBS wheels with a 5x108 bolt pattern and a hub diameter of approx. 65mm. I think they're a set of style 5 from a BMW e30. (correct me if I'm wrong) Not pretty as is but the price is right for the set and with a few hours of work (sanding, etching primer, sanding, filler primer, gunmetal paint, and clear coat) They could look good. They should be a direct fit correct? I've seen pictures of 96' 850's like mine with these wheels but just wanted to make sure these are good to use before I drive 2 hours to check them out.
Thanks for any Input!
-Luke
Old Dec 9, 2016 | 12:47 PM
Generally RWD cars have less offset than FWD - The standard offset for 850s is ET43 on a 6.5" inch rim so your ET36s will be closer to the fenders by about half an inch (1.4 inch for the offset plus 1/4 inch for the rim width). You need to measure the center bore for the wheels to get the right hub-centering rings (to fill a center bore larger than Volvo's 65.1mm size. Not sure if the e30s used 5x108 (Volvo) or 5x100 bolt patterns. If you know the year/model of the donor car, you can check at wheel-size.com
biteydog
Apr 30, 2010 09:32 AM
WrEcK
Mar 31, 2010 08:00 PM
milenkogt
Mar 28, 2010 08:30 PM
kburton66
Oct 19, 2009 06:19 PM
mick1232
May 19, 2009 02:59 PM
