Blinking tranny light
Hello all,
So I just bought a '95 850 sedan and the tranny light started blinking this afternoon. I was reading some of the posts and determined how to get the diagnostic codes. I got a code 122 which I think means "IAT sensor missing or faulty". Can anyone explain what this means? Thanks in advance.
RE: Blinking tranny light
There is a 99% chance you have a failing PNP switch. Row the shifter back and forth from low to park, quickly, 15 or 20 times and it might clearthe problem temporarily. They seem to fail more often in cold weather and after the car has been parked for a while when the grease gets stiff.
...Lee
...Lee
Thanks!! It has been cold here (Montreal, Canada) for the past couple of days and it only seems to happen when I first start driving. I rechecked the code on port A1 and got 313 which I think is faulty signal from PNP!!!
Is this something serious? I am not even sure what a PNP is!
Thanks again for the replies, this forum is fantastic.
Ed
Ed
PNP is a Park - Neutral Position switch. Actually it determines all of the shifter positions but will lock out the starter function if it is not in park or neutral. When they go bad there is no connection to tell the transmission what gear has been selected so it defaults to 3rd gear as a limp home mode.
It needs to be dealt with or it can damage the transmission permanently. It hates 3rd gear starts.
...Lee
...Lee
Its fairly simple and straightforward to replace it if you follow the instructions from one of the thread on this site or from tht link attached below:
http://volvospeed.com/Repair/pnpswitch.php
Good luck and feel free to get my help if you dont mind driving to Toronto
Happy Holidays
Happy Holidays
Wifeys1998XC70
09-21-2007 06:08 PM
