boost
Old Jul 21, 2006 | 02:48 PM
xhoodyx's Avatar
Default boost
I have a 1994 850 Turbo with BSR ECU and Cat back exhaust. The car over heated a year or so ago, and i replaced the motor and turbo (both Used). After i over heated the car, it went into a limp mode and will only go to 5 psi. I have replaced all my hoses, intercooler, and vaccum. I dont know where to look next. Possibly O2 sensors? the maf sensor, and the sensor where the 3 hoses come in from the turbo is new. I have alot of codes that come up, and i know the car is old, but i just want my boost back..
Any help would be appreciatted.
Old Jul 22, 2006 | 12:08 AM
code33's Avatar
Default RE: boost
What are the codes?
Have you tried clearing them?
Old Jul 22, 2006 | 12:28 AM
S70driver's Avatar
Default RE: boost
check the codes, find out what they are, fix the problems and clear the codes.
Old Jul 25, 2006 | 01:49 PM
xhoodyx's Avatar
Default RE: boost
I cant seem to find the sheet with all the codes, does anyone have it online?
plus how do you reset all your codes?
thanks
Old Jul 25, 2006 | 02:55 PM
S70driver's Avatar
Default RE: boost
Go to a local Advanced Auto Parts or something similar. They should be able to check the codes and possibly clear them too.
IPD sells a tool that you can reset your codes.
Old Jul 25, 2006 | 04:43 PM
code33's Avatar
Default RE: boost
http://www.volvospeed.com/dtc_a2_codes.php
http://www.troublecodes.net/Volvo/
Your vehicle is pre-1996. You should be able to pull the codes and reset without special tools. Locate the diagnostic unit to the right of the windshield washer fluid filler cap.
Old Aug 3, 2006 | 02:58 PM
xhoodyx's Avatar
Default RE: boost
i ran the codes, got a O2 sensor reading. I replaced the Sensor and now my #2 socket on the dianosis reads 1-1-1
does anyone know other reasons why I am only running 5 psi? if i put my ecu in another car that car runs fine...so thats out. IF i pull the hose off the wasteate it boosts right up.
Has anyone ever put a manual boost controller on?
i need to figure this out...A 850 with 5 psi boost = no fun
Old Aug 3, 2006 | 08:41 PM
xhoodyx's Avatar
Default RE: boost
how much is a new/rebuilt turbo?
if so where can i get one? new or rebuilt?
thanks
Old Aug 3, 2006 | 08:56 PM
S70driver's Avatar
Default RE: boost
http://www.vivaperformance.com
They sell new turbos.
Old Aug 3, 2006 | 11:42 PM
Default RE: boost
Did you replace the Boost control Valve yet?
Old Aug 4, 2006 | 05:12 AM
code33's Avatar
Default RE: boost
Yep, find the part that is causing the problem. Don't go around randomly swapping out parts like the turbo.
If you figure out that it is in fact the BCS (Boost Control Solenoid), then go ahead and install an MBC if you'd like. What you don't want to do is have mods with an existing problem.
Old Aug 4, 2006 | 01:57 PM
xhoodyx's Avatar
Default RE: boost
is the boost control solenoid , the one where the 3 hoses come in connected to the air box?
if so then i have replaced that.
im thinking that the wastegate is shut, and wont open...my guess?
Old Aug 5, 2006 | 04:35 AM
code33's Avatar
Default RE: boost
Yes, the BCS is the one w/ three hoses mounted to the air box.
A tear in the wastegate diaphram can cause this. Does it go past 5 then drop down to 5psi?
Check for codes again. You don't always get a check engine light with a fresh code.
thecheat
Sep 22, 2010 08:48 PM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
mygreenbomb
Feb 29, 2008 06:09 PM
blkwgnt5r
Mar 10, 2005 01:18 PM
