Brake knocking noise?
Old Aug 2, 2017 | 12:25 AM
TobyL's Avatar
Default Brake knocking noise?
Replaced the front brake pads recently, hoping it was the source of the screeching when I brake only then noticed that all 4 rotors were warped.. decided to replace the rotors when it would ship in but I still daily it around and now every time I would "cruise" like not add gas or hit the brakes, it would make this knocking sound from the front right wheel area. However if I press on the brakes or add gas, the knocking sound would go away, some how have a feeling its related to the rotors but could be something else. This also happened right after I added more Dex3 ATF since I barely had any power steering fluid left (just bought the car a week ago, new to the forums).
Any reasons why my front right area makes the knocking sound?
Thanks!
Old Aug 5, 2017 | 08:20 PM
could be the pads are loose - check to make sure they are the correct fit and installed properly. Don't see a connection to PS fluid if the noise changes when you tap the brakes.
LOVEvolvos
Apr 24, 2012 10:36 PM
macdogd
Mar 17, 2009 08:46 PM
Wing
Jan 30, 2008 01:52 AM
chris71 GB
Oct 27, 2005 08:54 PM
ripleydog
Jan 31, 2005 01:26 AM
