Brake Light
Old Jun 16, 2005 | 12:58 PM
skifloyd420's Avatar
Default Brake Light
I am having problems changing the rear left brake light from my 1994 850 wagon. I don't want to break anything in the process. Any help would be great. Also when changing the battery is there anything special that has to be done to change it or can I just remove the terminals and place another battery in.
Old Jun 16, 2005 | 01:17 PM
Default RE: Brake Light
Disconnect the negative terminal first.Then leave the key in the on position when installing the terminals.
Also make sure you have the radio code.
The lightbulb assembly should come out for you to replace the bulb.
nealeas
Mar 24, 2018 09:59 AM
glixons
Jan 4, 2015 06:15 PM
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
MaZoN
Aug 5, 2008 06:52 PM
mywifescar
Jan 13, 2006 12:59 PM
