Brake Lights
heres the instructions from the haynes for removal:</P>
1.)Detatch the cable from the negative terminal of the battery.</P>
2.)Remove the trim panel under the instument panel on the driver's side. On cars equipped with an airbag, remove the kneeguard beneath the steering column.</P>
3.)Depress the brake pedal slightly then push the stop light switch towards the pedal to release the locking sleeve</P>
4.)Pull the locking sleeve towards the switch plunger as far as it will go</P>
5.) Compress the switch side retaining catches and withdraw the switch from the pedal bracket. Disconnect the wiring connector and remove the switch.</P>
</P>
Hope that helps</P>
zinko
2001-2013 model year V70
Feb 11, 2014 07:18 AM
Scott V
Jul 21, 2013 02:28 PM
Mellott
Jun 13, 2011 11:41 PM
chrystald423
Mar 27, 2010 08:05 AM
