Burning Oil
RE: Burning Oil
Under the intake manifold on the passenger side of the car like behind the alternator is the vent box. It screws to the front of the motor. One hose goes up to the top of the motor. There is another one that goes over to the induction hose just before the throttle.
The first thing I would do it remove the hose form the mass flow to the motor.There is a connection that goes into the hose just before the throttle body. Inside the connection is a white screen looking thing. check and see if it is clogged. Also check the small hose connection to it. Make sure nothing at all is clogged in the system. Thats where I would start. Here is a link to a quick diagram of a parts list but it will give you and idea of the setup.
http://www.fcpgroton.com/product-exe...category_id/64
s70s70
12-26-2013 06:43 AM
enigma9011
09-01-2008 08:06 AM
