940 Wentworth oil burning
Old Mar 23, 2005 | 07:35 PM
spandalax's Avatar
Default 940 Wentworth oil burning
I have a K reg 940 turbo Wentworth estate (manual), which has 140,000 miles on the clock. The car is in great condition except for one thing - recently it has started to emit puffs of blue smoke when accelerating hard, and the oil consumption has increased. The oil warning light will flicker as the revs drop, and occasionally when idling. In all other respects the engine performs normally.
I need to get this sorted out, but I'm not very mechanically-minded. Is something serious happening? Any opinions gratefully received.
Old Mar 23, 2005 | 07:41 PM
Default RE: 940 Wentworth oil burning
Kind of sounds like the turbo is bad.Does it smoke more while the car is idiling?
Old Mar 23, 2005 | 07:55 PM
spandalax's Avatar
Thanks for the rapid response. There's no smoke when idling. The smoke happens at a certain point when accelerating under load - particularly when climbing hills. Once the 'smoke point' has passed there's no more until the next acceleration. The turbo operation seems to be normal - it cuts in when it should, and the performance doesn't appear to be in any way affected. As the oil level drops the warning light starts its occasional flickering, but the smoking stops. I add more oil to bring the level back to normal, and this stops the warning light, but the smoking is back. I use the car to drive to work and back - a round trip of 30 miles a day, and I'm adding around a litre of oil every couple of weeks.
Old Mar 23, 2005 | 09:04 PM
It still might be the turbo.It will kind of be like blow bye on an engine and the turbo will work like normal.
Old Mar 23, 2005 | 09:35 PM
spandalax's Avatar
Right - I'll speak to my mechanic about it. Many thanks for your help.
Old Mar 23, 2005 | 10:49 PM
No problem let me know how the car is once you get it.
Wentworthowner
Aug 5, 2009 11:47 AM
JoesephMackow
Jul 3, 2009 08:44 AM
bacardi
Jun 16, 2007 07:06 AM
ken
Aug 27, 2006 07:27 PM
VolvoAmateur
Sep 11, 2004 04:59 AM
