Burning oil at idle
Old Sep 5, 2017 | 02:04 PM
johnwartr's Avatar
Default Burning oil at idle
97 850R
Stock, other than a 5 speed swap, IPD lowering springs, bilstein HDs and a few silicone hoses.
325,xxx miles
I purchased this from the previous owner last fall and have been working my way through its various issues as time allows.
After replacing the front exhaust cam seal, which was hemorrhaging, I now burn a lot of oil at idle after sitting for 5 minutes idling.
I'm trying to determine whether I have leaky valve stem seals, a worn out turbo, or ?
I have a nice, tight low mileage 16T from an 04 C70 with ~130K and a spare T5 head I can rebuild.
Is there a good way to tell what the likely culprit is? I've not replaced the PCV but it passes the glove test...
Old Sep 5, 2017 | 10:18 PM
a few things to check
1) pull off the intake tube going into the turbo - you should be able to see the vanes via port and can feel around for any end play
2) do a wet/dry compression test to see if the rings are up to snuff (about 150 psi for the turbo engines)
3) not sure about how to test for stem seals - an old school method useful on manual trannys was to go hard in second gear then lift the throttle - if you saw a cloud of blue it meant you were sucking oil past the seals (or rings too?)
Old Sep 5, 2017 | 10:30 PM
tryingbe's Avatar
20 year old stem seals are done.
Old Sep 6, 2017 | 03:58 PM
firebirdparts's Avatar
If sitting 5 minutes at idle is the key to it, then I think it's the valve stems and the diagnosis is over.
Old Sep 6, 2017 | 07:25 PM
difflock54's Avatar
Blue swirling smoke from exhaust on acceleration after coasting down a longish incline is also indicative of valve stem seal issue.
mp4805
Sep 4, 2011 08:21 AM
91shelby
May 20, 2011 06:08 PM
enigma9011
Sep 1, 2008 08:06 AM
mfiwd
Mar 1, 2007 11:05 PM
