A/C light won't turn on, what may be the cause?
Old Mar 1, 2005 | 04:36 AM
Geetarslim's Avatar
Default A/C light won't turn on, what may be the cause?
I have a 94 850 and when I turn on the A/C switch the light won't come on. Is this indicative of a major A/C problem? I bought the car from my Father, and he had the A/C system replaced. He did tell me they had to remove the dash. This work was done 2 years ago. Is this a fuse problem (hoping) or will I have to shell out another $1250 to replace the system? The car was very well taken care of and runs great. If I decide not to fix, would this effect any other system? Please any help would be greatly appreciated.
Thank You
Old Mar 1, 2005 | 10:05 AM
Default RE: A/C light won't turn on, what may be the cause?
If you decide to not fix it no it wont affect anything else.If you have a test light check under the hood follow the A/C lines to the body by the windsheild.You will see an electronic valve in line called a low pressure switch.Turn on the A/C and check for power there.If you are low on freon you will have power on one side only.The light on the dash for the A/C might just be bad.Or you could also have a bad A/C head unit.Do you have manual A/C controls or electronic? If you have an auto temp control on the dash it is electronic.If you just have 12345 on the control it is manual.
Old Mar 1, 2005 | 01:13 PM
Geetarslim's Avatar
Hey Tech,
Thanks for responding so quickly, I have manual controls, I will also check the suggestions you have made once the weather gets better here. Thanks again for the GREAT help...
Old Mar 1, 2005 | 01:48 PM
Let me know how you make out.
Old Mar 12, 2005 | 10:11 AM
Geetarslim's Avatar
Hey Tech,
The problem was with the light, my father also confirmed it. He told me the A/C works well, the indicator light went out and needs to be replaced. THANKS AGAIN FOR THE GREAT HELP!
Old Mar 12, 2005 | 12:30 PM
Your welcome if you have anymore quiestions feel free at ask.
Gustav
Nov 11, 2017 01:01 PM
PapaBruce
Mar 12, 2014 03:49 PM
smoothhd
Jul 31, 2011 08:35 AM
donf
Sep 8, 2009 04:36 PM
exotek
Nov 11, 2008 09:32 AM
