Cabin filter
Old Apr 3, 2007 | 09:21 PM
floryed's Avatar
Default Cabin filter
Can anyone tell me where the cabin filter is at, and how to get to it?
Thanks!!!!
Old Apr 3, 2007 | 10:23 PM
mordezmoncou's Avatar
Default RE: Cabin filter
id like to know too.
Old Apr 4, 2007 | 02:06 AM
JPN's Avatar
JPN
Hi,
The cabin (pollen) filter is at the corner of the outside air intake shroud (under the windshield wipers). I'll attach some pics (courtesy of Cam's Factory & FCP Groton), but you may need to install it yourself, if it didn't come as original equipment. Groton has an aftermarket retainer. Call & ask them to see if the retainer comes with installation instructions (though it doesn't look too difficult).
Good luck,
JPN
↓Note, that these pics (except for the last 2, which came from FCP Groton) are taken from Japanese web and the location is the opposite on your car (except if you live in the UK).
[IMG]local://upfiles/6892/8BE625F416C34E2396BD861F63F65FA0.jpg[/IMG]
[IMG]local://upfiles/6892/C0506F5B1D02490FBBB87C5E4D1D3656.jpg[/IMG]
[IMG]local://upfiles/6892/7696C735B06647F28D352E9D7968FA10.jpg[/IMG]
[IMG]local://upfiles/6892/E787C9D18A6741628598437AA3FE9563.jpg[/IMG]
[IMG]local://upfiles/6892/4125B923B36D41788842FB65A980DEE3.jpg[/IMG]
Old Apr 4, 2007 | 03:48 AM
info2x's Avatar
filter will be on the passenger side, so don't get confused by JPN's picture
[align=left] [/align]
Old Apr 4, 2007 | 03:56 AM
JPN's Avatar
JPN
Thanks for your correction, info2x. The pic was taken from Japanese web, where Volvos have the steering wheel on the wrong side[8D]
JPN
Old Apr 4, 2007 | 01:28 PM
info2x's Avatar
I figured as much.
Old Apr 4, 2007 | 03:06 PM
B1mmer's Avatar
I would also consider getting a charcoal filter. Yes, it's more expensive, but it does keep out a lot of the smells from the outside of the car. - AB
Old Apr 6, 2007 | 11:30 AM
JPN's Avatar
JPN
↑+1
Activated charcoal is usually the best material for getting rid of odor.
Charcoal filter: $25
Normal filter: $17
http://www.fcpgroton.com/volvo850tuneup.htm
JPN
The first pic is the charcoal.
[IMG]local://upfiles/6892/6FB655034CAF4C75ADD454F9E899E8C2.jpg[/IMG]
[IMG]local://upfiles/6892/2A53FE5ECEAA405C9B0AABA6F4021569.jpg[/IMG]
Old May 5, 2007 | 08:46 PM
Ward850T's Avatar
There are two T-25 screws on the top that you undo and you can get it out. I just pulled mine out today on my 850, and except for some debris in the pleats I could see light through it so I would assume it is good enough to put back.I tapped it flat on a solid surface and put it back in.
debargha
Feb 24, 2015 10:46 PM
nigel_miguel
Jan 7, 2012 05:09 PM
bluemagicbus
May 17, 2011 07:18 AM
edahlgren
Oct 21, 2010 06:24 PM
Ahmed
Mar 28, 2008 04:22 PM
