Cam and cam gear problem
Old 07-07-2008 | 05:51 PM
Crate45's Avatar
Default Cam and cam gear problem
i recently tore down the headof a 92 850 to replace six bent valves. when i did that i separated the cam gears from the cam shafts. Now, my problem is each cam has three equally space bolt holes 120 degrees apart giving me three choicesand i didn't mark the gears before removal. so, i don't know how to install the gears so the TDC markson the gearwill line up properly, placing the cam at the correct timing. any help solving this problem will be greatly appreciated. thanks
Old 07-07-2008 | 07:22 PM
Ozark Lee's Avatar
Default RE: Cam and cam gear problem
You need to lock the cams in place. Haynes has a good description of how to do it along with "plans" for a homemade tool. Just pay attention to the offset of the slot on the back of the cams. Your next problem is going to be getting the cams timed back correctly. The cam sprockets don't have holes, they have slots that allow for adjustment of the cam timing. I always use spray paint to mark where the bolts were centered before I take them off but centered in the slot is usually about right.
...Lee
Old 07-07-2008 | 11:23 PM
Quick Brick's Avatar
Hello Ozark Lee and Crate45,
Lee. Is this what you are speaking of,
or is it this one,
I hope that this will help you Crate45.
[sm=icon_cheers.gif]
Old 07-07-2008 | 11:34 PM
Crate45's Avatar
Thank you for the help. That should be exactly what i needed.
Schaeffy
01-08-2014 07:36 PM
carlheat
10-25-2010 11:36 AM
Aberk
11-29-2008 09:58 PM
Carbuff
05-19-2005 05:44 PM
