Camshaft oil seal
Old Apr 20, 2006 | 10:44 PM
NSF Ed's Avatar
Default Camshaft oil seal
can anyone tell me which way the oil seal on the exhaust cam, behind the cam position sensor, goes in? Is it the typical back of the seal open cavity inward or outward. My manuals seem to contradict each other. The current seal is popping out and leaking like a sieve.
Old Apr 21, 2006 | 12:14 AM
Default RE: Camshaft oil seal
Look on the back of the seal you will see a little spring. That part goes in first. The outside of the seal should look kind of flat. The U shaped should go in.
Old Apr 21, 2006 | 01:13 AM
NSF Ed's Avatar
Thanks for the info- that's the way I assumed it would go in. The Haynes manual says to put it in the other way. Do you know if a crankcase ventilation issue can force the cam seals out? I'm trying to figure out why the seal is almost 1/2 way out of the seat.
Old Apr 21, 2006 | 01:16 AM
Possible but how many miles on the car?
If alot then it might just be old and hard.
Old Apr 21, 2006 | 01:19 AM
NSF Ed's Avatar
1994 with 133K miles.
Old Apr 21, 2006 | 01:46 AM
Possible from age as well.
Double check the Vent system.
grndslm
Apr 14, 2013 05:03 PM
JHudson
Jun 21, 2010 04:04 PM
bobtucson
Sep 29, 2009 10:47 AM
arball
May 13, 2008 09:10 PM
