Removing camshaft oil seal
Old Sep 27, 2009 | 02:07 PM
bobtucson's Avatar
Default Removing camshaft oil seal
While replacing my 940's timing belt I tried to replace the cam gear oil seal and bent every pick and hook tool that I tried without any success
How aggessive can you get without damaging something else? What are your favorite tools to do this job?
thanks, bob
Old Sep 27, 2009 | 02:41 PM
TURBO 245's Avatar
Use a seal puller or screwdriver,seal pullers a available from any parts store for 5 to 10 bucks.Small pick tools will not remove a the seal.
Dan
Old Sep 27, 2009 | 04:42 PM
bobtucson's Avatar
Default Seal puller
Thanks Dan for pointing me in right direction. I'll pick one up tomorrow.
Thanks for the picture also.
bob
Old Sep 27, 2009 | 07:33 PM
tedv's Avatar
Much better way is to just remove the cam retainer that holds that seal in place. No scratching, no frustration... just have to remove the valve cover first.
Old Sep 28, 2009 | 10:07 AM
adub96's Avatar
use a thin kitchen knife, does it every time no scratching.
Old Sep 28, 2009 | 11:43 AM
bobtucson's Avatar
Yet another option, which way would the seal come out then, towards engine or away?
thanks, bob
Old Sep 28, 2009 | 11:46 AM
bobtucson's Avatar
I tried a utility knife when the "pick" attempt failed and I didn't seem to be getting anywhere. Afraid of scoring the metal, I gave up on that.
btw, when the new seal goes on, do you use any lube on the shaft?
thanks, bob
Old Sep 28, 2009 | 11:53 AM
adub96's Avatar
well, you can slip it in between the seal and the cam shaft and since you are getting rid of the seal anyways, go to the side and pull it out towards you. When you go to put the new one on I like to pack the pack of the seal with grease so it kinda holds that little spring in better.
Old Sep 29, 2009 | 10:47 AM
bobtucson's Avatar
Thanks, grease sounds good.
And thanks to the forum for sharing your experience and knowledge.
bob
grndslm
Apr 14, 2013 05:03 PM
JHudson
Jun 21, 2010 04:04 PM
arball
May 13, 2008 09:10 PM
NSF Ed
Apr 21, 2006 01:46 AM
