Can't get ECU codes to display on '95
Old Aug 21, 2005 | 11:29 PM
jcmartin's Avatar
Default Can't get ECU codes to display on '95
I have followed the instructions in the Haynes manual and every other source I can find, but the flashing LED will not flash.
I put the probe into Bank A socket 2. I turn the ignition key to "ON" -- radio and AC come on. I push the button for one second and the LED lights up. When I release the button, no codes, not even 1-1-1, are displayed. I do the same exercise for Bank A, Socket 6. Start the car. I spit and squint in my most Josey Wales threatening manner to intimidate the Swedish immigrant. Nothing happens.
What am I doing wrong?
Thanks in advance,
JM
Old Aug 22, 2005 | 12:43 AM
Default RE: Can't get ECU codes to display on '95
Do you have an OBDII plug inside the car? It will be in the center console if you have one. Under the ashtray.
Old Aug 22, 2005 | 02:00 AM
jcmartin's Avatar
I didn't think that the 1995 had an OBD. If it does, then I'm completetly lost.
JM
Old Aug 22, 2005 | 03:18 AM
Lichty17's Avatar
The OBDII plug is in the center console rite under the Change holder. The Change holder pops rite off and even says OBDII rite on the change holder.(the text is really small though) Atleast that is where it is on my 95
Old Aug 22, 2005 | 11:17 PM
rp850's Avatar
Doesn't hurt to double check:
Key should be in position II
Maybe try putting the jumper in A2 with the car off, then go to position II and press button for 1 second. Do the eye squinting thing again and see if that works. [>:]
On my 95 the OBDII port is present but not functional. Autozone will read OBDII codes for free if you want to confirm whether it works. I get everything from the OBDI port under the hood.
Alan Eliass
Oct 29, 2013 09:04 AM
websrfr
Oct 2, 2009 12:21 PM
volvodad
Feb 15, 2009 09:18 AM
bigern45
Aug 5, 2008 08:14 AM
