Can't pass emissions
Old Nov 28, 2010 | 07:20 PM
  #21
Replaced my front O2 sensor with a used one. No more cel.
Old Nov 29, 2010 | 05:33 PM
  #22
kockyhardrockr's Avatar
Originally Posted by boxpin
Run your gas tank down to two gallons of gas. Go to Home Depot and buy a gallon of Denatured Alcohol. Poor the entire gallon in the tank. Take it straight to the smog shop and have them run the test. It will pass with flying colors no matter how bad its running. The Denatured alcohol burns so clean you will pass. After the test drive it out then fill your tank full again with gas.
Happy smogging
(been doing this for 4 years now with my truck)
Boxpin you the man. I've been getting noxious fumes out the tailpipe since after I whacked that deer. My emissions are overdue and I was getting worried I wouldn't be able to find a dirty inspection shop to get the damn little sticker.
But when I changed my plugs they were wore down pretty round and white tips. With the black soot i get out the exhaust and my halfass compression test, I'm sure the piston rings are worn and it's blow-by/oil coming out the exhaust. Can't afford a rebuild or replacement engine till july/aug.
Any trick to get that to pass emissions?
I know this will have everyone screaming but I'm thinking of putting this XADO rubbish directly into my car's cylinders. Followed by oil/filter change to thicker oil.
EdistoSC
1998-2000 model year V70
Feb 15, 2015 04:40 PM
geemurphy
Oct 16, 2013 11:01 AM
obxphx
Aug 6, 2012 02:06 PM
jshmhn
Feb 18, 2010 07:08 PM
pismo
Jul 20, 2008 04:28 PM
