Car not going into 4th gear again
RE: Car not going into 4th gear again
Was it an AT or MT?
If AT, it could be the solenoid, which you can now buy at FCP Groton. Or it could also be an electronic control problem, in which case you need to pull codes & clear them and see if the same codes return. I would also check the correct fluid condition & level.
http://www.fcpgroton.com/volvo850tranny.htm
If MT, I am not familiar with Volvo's MT, but it is probably an internal problem if the rest of the gears are shifting fine. Usually that is a problem caused by worn out synchroniser on each gear. If the clutch/hydraulic systemwas bad, you would have difficulty shifting any gear.
I'll let other experts provide different perspective.
JPN
JPN
hmm. i know in my ex's 95 850 turbo, if we would let it sit for a day or overnight, it wouldnt want to switch out of 1st into 2nd. we would just put it in L then back to D. I know you .....,probably shouldnt do that in 4th gear...... but he told me that it was some switch that tends to go out after those cars get so old. I dont know. Not trying to sound stupid.. I'm still learning alot about cars. Actually. Now Im just rambling. lol. goodnight.
elchingon2002
07-22-2014 07:09 PM
