Car pulling wierdly even after alignment
Old Mar 13, 2011 | 12:56 AM
91shelby's Avatar
Default Car pulling wierdly even after alignment
Ok after i replaced me ball joints and struts i had my alignment done, though now it still pulls to the left randomly not all the time, and it kinda feels like its wobbling sometime when i brake. like the wheel goes back and forth....
Old Mar 13, 2011 | 07:18 AM
Henry10's Avatar
I had the same symptoms, right-side though. Found --- nut on top of the strut was not tightened fully. Had to take them off again.
I would also make sure that the lug nuts are tightened at the specified torque - 75.
Old Mar 13, 2011 | 02:11 PM
v70man's Avatar
Check the run-out on your discs it sounds like you might have a braking problem.......
Old Mar 13, 2011 | 02:50 PM
A guy wrote about that problem a month or so ago and realized that he had 3 lug nuts missing. I mean WHAT???
If it happens while braking, my 1st guess would be rotors.
Old Mar 14, 2011 | 12:27 AM
91shelby's Avatar
could bad strut mounts/spring mounts cause it? it also pulls randomly when driving with no brakes applied
Old Mar 14, 2011 | 07:00 AM
Henry10's Avatar
How did they look when you replaced the struts? Did you get this problem AFTER your replaced them, or was it there before?
Another thing -- the spring should be seated correctly at the mount -- the top tip of the spring needs to rest on the stop on the mount.
How are the other suspension parts: 2 outer tie rods, 2 inner tie rods?
DO you hear anything?
Old Mar 14, 2011 | 02:28 PM
91shelby's Avatar
it would go back and forth before, but the ball joints were shot, and the mounts looked fine when i replaced the struts, i only get a noise when backing out to the left(towards the passenger side, noise comes from the drivers side
Old Mar 14, 2011 | 03:17 PM
JimKW's Avatar
Could be bad tires. Even if they look fine the rubber could be separating from the steel belts. I have had it happen to me and thought the front end was falling off the car. Had it towed to the dealer only to find ou it was just the tires. Same thing happened to my in laws. Both times they were Pirelli P6 tires. Have not had Pirelli's since.
Old Mar 14, 2011 | 07:13 PM
matt01's Avatar
it happens alot after an alignment. the shop puts everything at 0 as much as possible, after that if you have any pulling it could be related to tires, tire pressure, lugs..
mine was aligned and pulled like crazy, once i put on my new winter tires it was straight as an arrow. I know once i go back to my summers it will pull
try a tire rotation if it changes at all, its probably that
Old Mar 14, 2011 | 11:19 PM
hookuspookus's Avatar
are the lower A-Frame bushings good ?
Old Mar 14, 2011 | 11:29 PM
your problem is on the right side , if you touch the brakes and it pulls to the left your problem is on the right side if you hit your brakes and it pulls to the right its your left side , sounds like you have a warped rotor ( the wobble) the problem with the pulling sounds like a bad caliper or brake hose , only if it happenes while you brake , also a bad caliper will make it pull with NO brakes being applyed . so what ever side its pulling to its the opposite side that is giving you the problem
Old Mar 15, 2011 | 12:28 AM
91shelby's Avatar
lower bushings are known good, i just replaced the entire control arm on both sides and added the ipd swaybar endlinks and new biltstien touring struts
Old Mar 15, 2011 | 08:54 PM
91shelby's Avatar
tires are known good, as it did the same thing with my winter wheels and tires too
Old Mar 22, 2011 | 09:15 PM
91shelby's Avatar
well i tried to spin the wheels with the car off the ground and it in neutral and well the drivers side rotor rubs and spins of and on and the passenger side is like the brake is lightly on all the time, would have over tightening the lug bolts with an impact wrench and driving on them possibly warp the rotors?
Old Mar 22, 2011 | 09:55 PM
Who put the wheels on? I had a tire shop rotate & balance tires on a S90 and they put the wheel on wrong. Wedged the pin in one of the wheel space studs and cause the wheel to wobble like crazy but it didn't pull.
I had a pull once on my 850, though a wheel was falling off and it turned out that the tire shop put one of the wheels on so the directional tire was turning in the wrong direction.
As for having the car off the ground and the wheels spinning, that is not easy since the car is FWD. If they do turn, they should turn smoothly. Bad rotors shouldn't make the car pull.
Old Mar 22, 2011 | 11:18 PM
91shelby's Avatar
they do not turn smoothly i can hear and feel the friction from the rotor draggin on both sides its just worse on the passenger side, tires are going the right direction, a long time ago i had used an impact wrench to put the wheels on until recently i found a thing not to over tighten the wheel lug bolts.
Old Mar 23, 2011 | 07:04 AM
  #17
Henry10's Avatar
If there is drag, calipers are not behaving very well.
Old Mar 23, 2011 | 02:29 PM
  #18
No . if the car is pulling to the right your left caliper is bad , if your car is pulling the left your right caliper is bad
Old Mar 23, 2011 | 02:33 PM
  #19
could also be bad lower A- frame grometts and a slight rubbing of the pads on the rotor is normal , just as long as they are not locked or really stiff and hard to turn , then that would mean bad caliper or bad brake hose
Old Mar 27, 2011 | 12:20 AM
  #20
91shelby's Avatar
come to find my passenger side motor mount is shot, could this cause some if these issues?
hrdwdpro
Oct 7, 2013 10:28 PM
lukaspanic
Mar 17, 2012 12:49 AM
gingersnap
Jan 10, 2012 11:33 AM
Cashin18
Sep 28, 2011 08:38 PM
vinnyman72
Feb 7, 2011 09:26 PM
