Car stopped and won't start - ECU???
Old Apr 8, 2005 | 12:43 AM
kdfair65's Avatar
Default Car stopped and won't start - ECU???
My '95 850 GLT stopped yesterday and won't start - just turns and turns. The upshift arrow for the transmission mode flashes, along with the light for E and S mode. I check the codes and got several, but two pointed to the IAC and the TPS. Using my Chilton repair manual, I checked the plugs for these two, and was not getting any voltage from the ECU. The repair manual said that I should then check either the harness or the ECU. So I pulled out the ECU and did a continuity check from the ECU harness to the sensors, and all three wires on each were fine. ..
....so could my ECU be the problem. I noticed in the electrical diagram that the fule injectors are on the same circuit as the IAC, so I check them and they are also not getting any voltage.....
..any suggestions? How much is it to replace a ECU?
Old Apr 8, 2005 | 09:50 AM
Default RE: Car stopped and won't start - ECU???
Did you get codes out of the transmission?
Old Apr 8, 2005 | 03:10 PM
kdfair65's Avatar
The only code I got from A1 was 223, which is for the TPS, so that is why I checked the wiring for it and discovered no voltage
Old Apr 8, 2005 | 04:32 PM
Any codes in the ECM?
Old Apr 8, 2005 | 05:52 PM
kdfair65's Avatar
I got a 113 and 122 code from, but no ther codes from ant other port
Old Apr 8, 2005 | 07:51 PM
Just for giggles try to unplug the mass flow sensor and try to start it.
The code in my book is
113 fuel injectors
122 air intake temp sensor signal absent or faulty.I think that sensor is in the mass flow.
Old Apr 8, 2005 | 09:35 PM
kdfair65's Avatar
Thanks..i tried unplugging the mass airflow sensor, and it still won't work.
I checked this senssoe, and it is not getting any voltage (manual says it should be battery voltage)
I checked the electrical diagram, and the mas air flow, IAC along with the fuel injectors and some other sensors should be getting voltag from the circuit that comes from the fuel injector relay. I'm not sure if this relay is working. I notice in the diagram that this same circuit send a signal to one pin on the ECU, so I pulled the ECU out to check the voltage at the pin that is coming from the fuel injector relay (that also goes to the other sensore mentione above) and I get nothing, with the ignition on, or when I turn it to start...
..could the fuel injector relay be the problem? and If so, where is it located? My repair manual only shows it in the electrical drawings, bu no mention of its location.
Old Apr 8, 2005 | 10:35 PM
I think it is under the cover around the fuse panel.Remove the 4 t-25 screws and remove the cover and there is relays under there.
Old Apr 8, 2005 | 10:54 PM
kdfair65's Avatar
I chece\ked those. The fuel pump relay/contol is ther, but I don't any of the other relays are for the fuel injectors....but I may be wrong..i will check again
Could the fuel injector relay be my problem?
Old Apr 9, 2005 | 01:28 AM
Possible but if you can get ahold of a noid light you should check injector pulse.Make sure the injectors are getting power and grounding properly.
The only other thing I can think of is there is a relay by the cooling fan relay.It is a square relay with 4 wires going to it.Make sure the wires are clean and tight.
Old Apr 9, 2005 | 02:26 AM
kdfair65's Avatar
Thanks...I'll try this in the morning...had enough for one day!
Old Apr 11, 2005 | 01:00 AM
kdfair65's Avatar
I FIXED IT!!
After locatingthe fuel injector relay, which was where it was suggested to be, I noticed it was not getting battery voltage all the time, so I checked the wire comin to at the battery, and it's connection wa eroded. I changed the connection, and it started!!!!
I checked for trouble codes, and all were gone!!! Drove car for 3-4 hours today with no issues. Runs just as before.....and a loose connection casued all of that trouble.
Thanks to all who offered suggestions!
Old Apr 11, 2005 | 01:15 AM
Im glad you figured it out.I was racking my brain trying to come up with more ideas.
Im going to keep it in the back of my mind so I remember this one.
Thanks for posting the fix!!!!
fochs
Aug 18, 2012 06:30 PM
makaveli2k
Aug 8, 2012 12:32 PM
91shelby
Jun 20, 2011 06:56 PM
exotek
Nov 11, 2008 09:32 AM
bigern45
Aug 5, 2008 08:14 AM
