car wont start
Old Sep 22, 2008 | 08:21 AM
viper92086's Avatar
Default car wont start
hey guys we have a 94 850 turbo that will not start and i was wondering what could cause this. the car cranks over sometimes but when it does it will only stay running while revving. once we let off it dies. Now my friend was saying the maf sensor is a common problem to these cars, could that be it? i also noticed when we turn the key to ignition you hear a whining sound coming from the passenger side engine bay. any help would be appreciated thanks
Old Sep 22, 2008 | 08:26 AM
Psaboic's Avatar
Default RE: car wont start
It sounds like the coolant temperature sensor might be bad. Is the whining the engine cooling fans coming on? Is the check engine light on at all?. If so, you need to pull the codes to give us a better lead on what is going on. If the light is on and you come up with code 1-2-3, then it is most likely the coolant sensor
Old Sep 22, 2008 | 11:45 AM
viper92086's Avatar
the whining was coming from the headlight area. the fans were not on. and i dont remember if there was a engine light, but ill check again
Old Sep 23, 2008 | 06:30 PM
Unplug the mass flow and see if it idles decent. It will set a code though.
suze
Jan 30, 2014 07:42 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
furball3
Jan 28, 2007 03:31 AM
Boosted_s80
Nov 15, 2005 08:24 PM
t5killer
Oct 26, 2005 08:45 PM
