car wont start need help
Old Oct 16, 2009 | 07:46 PM
csigrist's Avatar
Default car wont start need help
i have a 94 volvo 850 that wont start. I removed the starter and had it rebuilt, when i went to put it back on it still would not start. I know that the problem not in the starter, had rigged up a toggle switch directly to the starter and can start it that way. Cant figure out what is wrong. I have been told by others to either replace the ignition coil or to replace the pnp switch. does this seem right.where should i start.
Also have had been having a problem with it shaking real bad when i put it in reverse. also it doesnt really go anywhere if you press the gas in reverse i can let it idle back and its no problem. what can i do to fix it. or does the transmission need to be replaced i dont have any problems in any other gear though.
thanks for you help
cassie
Old Oct 16, 2009 | 07:57 PM
csigrist's Avatar
Default update
ok went out to try and start the car transmission light and the economy/sport light is flashing now. what does that mean
Old Oct 16, 2009 | 08:13 PM
Carrots's Avatar
that suggests an issue with the PNP switch. ECM not getting a signal from it will cause the transmission light to flash. Pull codes, but I'll bet that that's your problem.
Old Oct 17, 2009 | 01:36 AM
850tony's Avatar
i vote pnp all the way!
suze
Jan 30, 2014 07:42 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
eric1164
Apr 3, 2008 07:51 PM
furball3
Jan 28, 2007 03:31 AM
t5killer
Oct 26, 2005 08:45 PM
