caster
Old Jun 22, 2008 | 06:45 PM
bitter356's Avatar
Default caster
Any aftermarket parts or procedures to adjust caster. My drivers side 3.32 dregees (2.33-4.33) Passenger side 3.97 degrees, still pulls to the left, which has the least positive angle. Replaced front tires with Yoko S-Drive tires after alignment shop informed me that radial tire pull is my problem. Guess what, still pulls to the left. Help!!!!
Old Jun 22, 2008 | 06:50 PM
S70driver's Avatar
Default RE: caster
Catser? Do you mean camber?
Old Jun 22, 2008 | 07:28 PM
bitter356's Avatar
Default RE: caster
Yep, caster. Camber is .12 degrees drivers side, .03 degrees passenger side. -1.0 to 1.0 degrees is the min-max range.
designstate
Sep 29, 2009 07:27 PM
rodmodder
Mar 31, 2009 08:34 AM
