CD Changer SC 710 not working
Old Aug 12, 2007 | 03:16 PM
SupremeBeing's Avatar
Default CD Changer SC 710 not working
I just got a 1996 Volvo 850 from my father, who has had it for the last 4 years and maintained it well. I love the car, but as of the last few weeks, I guess, the CD changer has stopped working. It's an SC-710 6 CD changer, and it's worked great up till now, but now when you hit the CD button it just says E-2 and doesn't play. My dad isn't sure whether there's still a disc in the player or what but the box that holds the CDs is now empty and it still doesn't work.
I've read that "popping the fuses" might fix the problem, but I don't know what that is.
Please advise.
Old Aug 12, 2007 | 08:28 PM
JPN's Avatar
JPN
Default RE: CD Changer SC 710 not working
Hello SupremeBeing,
First of all, welcome to the forum! I hope you find it helpful & enjoyable.
As to the CD changer, I am useless as my 850 did not have such fancy device. Please wait a day or two, until someone else with the necessary knowledge can reply to you. In the meantime, this may be of some reference to you:
http://volvospeed.com/Repair/sc816.php
Wish you luck,
JPN
Old Aug 13, 2007 | 10:23 AM
Thanks, I'll try that ^^. Also, if it helps, I checked the error code again and it's actually E-02.
Old Aug 14, 2007 | 12:30 AM
I pulled out the radio, and pried off the black bars, but on the 710 there isn't a switch where it said there would be, so it's still not working :/
Old Aug 14, 2007 | 08:10 AM
JPN's Avatar
JPN
I'm sorry that your radio was configured differently.
At this moment, I can only suggest another cheap fix, until someone who has dealt with the same issue could reply.
Optical drive devices (CD player, DVD, etc) generally last about 7-10 years (longer if you're lucky), then they quit. Most often it is the laser pick up that gets screwed up. You could perhaps try commercially available disk player cleaner and try to blow dust off from the disk tray insert opening with a can of air duster.
This is all I can do for now. I wish I could help you better.
JPN
Old Aug 14, 2007 | 01:37 PM
Will do. Thanks
Old Aug 14, 2007 | 05:22 PM
RedTurbo850's Avatar
Wait, is your Cd changer like the one in the picture, or do you have the CD changer in the trunk?
Old Aug 14, 2007 | 05:32 PM
The changer itself is in the trunk. There's nowhere to put a CD in on the dash radio console.
Old Aug 14, 2007 | 07:08 PM
I have no clue where to find radio codes/explanations...
So I can only recommend you call the dealer and ask if they can find out what e-2 means. If they can't, give them your VIN and ask for your reset code/radio code and maybe try disconnecting the battery to reset the radio.
shoeboxOH
2001-2013 model year V70
Mar 20, 2016 04:50 PM
Raff22
Sep 14, 2013 12:03 PM
rspi
Aug 8, 2012 12:42 PM
Ewalt1018
May 11, 2011 06:38 PM
DJ420
Sep 4, 2010 03:26 PM
