SC 710 to SC 815
Old Sep 10, 2013 | 06:55 PM
Raff22's Avatar
Question SC 710 to SC 815
Hi,
My wife just bought a 96 Volvo 850 and it comes with the SC 710, but the rear speakers don't work. She wants a CD player so I would like to know if I can just pull out the 710 and pop in an 815. Are the plugs the same? Thanks.
Old Sep 11, 2013 | 01:23 AM
scutyde's Avatar
Rear as in rear doors or D pillar? Are any speakers there? Did you take off the speaker grille and checked?
All SC should work in the 850 plug&play, SC 900 and 901 need an external amplifier all others can work without it.
Old Sep 11, 2013 | 03:54 AM
Yes the plugs are the same. You can also get decks from the 960, S90, S40, etc. The faceplates of the S70 & V70 are a different color and they have an antenna booster wire that you won't use but yes, the radios will swap right in.
I usually write the code in the passenger side sun visor flap so it's super handy.
Old Sep 14, 2013 | 12:40 AM
Raff22's Avatar
Default Rear Speakers
Thank you for your reply! Rear as in behind the back seats. I did remove the grills and the wires are ok. Was told that problem is common and means the head unit is gone. If I set the fader to rear and turn the volume up all the way, I can hear the rear spkrs a little. Since I want to replace the 710 with an 815, hopefully they will work(?)
Old Sep 14, 2013 | 08:52 AM
97black850's Avatar
i swapped a head unit and it didn't make mine work. its probably the speakers
Old Sep 14, 2013 | 10:22 AM
Someone likely blew them. Rare because those rear deck speakers rock!
Old Sep 14, 2013 | 12:03 PM
97black850's Avatar
i agree, all eight speakers work in my 94 and its great
bond007
Apr 24, 2011 10:47 PM
DJ420
Sep 4, 2010 03:26 PM
VOLVO_KING
Jan 23, 2010 09:00 PM
wutmt
Oct 11, 2009 09:56 AM
SupremeBeing
Aug 14, 2007 07:08 PM
