change windshield wiper
Old Apr 19, 2009 | 04:06 PM
JimBee's Avatar
Default change windshield wiper
O.k., I admit this is a duh question. Having never changed a wiper blade on this 850 I can't figure out how the release catch works.
Thanks! jb
Old Apr 19, 2009 | 04:14 PM
I just did one last night. There is a clip under the arm. Just squeeze the clip and pull the whole wiper blade off.
Old Apr 19, 2009 | 04:27 PM
JimBee's Avatar
I realize that's what the manual says. I see a bracket there, but I don't see anything that can be squeezed. The wiper rotates. I'm supposed to rotate it to a right angle with the arm. Then all I see is a bracket with two fixed sides, nothing to squeeze.
Is there an enlarged picture somewhere?
Thanks.
Old Apr 19, 2009 | 06:24 PM
Here is the pic of my 850 blade. The tip of the screwdriver is on the release lever.
Old Apr 19, 2009 | 07:43 PM
JimBee's Avatar
Default not the same design
Thanks for the pic. I see the problem, mine doesn't have the release tab. I poked a screwdriver into very small rectangular opening, tried to pry the metal in there, nothing seems to move. It kind of looks the one in rspi's pic but without the tab. Any ideas?
JB
Old Apr 19, 2009 | 09:32 PM
nonsense619's Avatar
same thing happened to me.are you pushing down on the blade? push straight down onto the arm..also by "I see the problem, mine doesn't have the release tab." do you mean it broke off? you should still be able to pry at it with a small screwdriver.
Old Apr 19, 2009 | 10:09 PM
If you look just above the tab, there is a hole in the arm that is fulled with the release latch. Push in the latch with a small cross tip driver or something and pull down at the same time.
How often do you guys change your blades? I cant wait to change mine ever year or two.
Old Apr 19, 2009 | 10:15 PM
Johnny Mullet's Avatar
Worst-case scenario, you can simply hack out the clip with a good pair of diagonal cutters. It's only plastic.
Old Apr 22, 2009 | 02:28 PM
Dads850's Avatar
I change mine to winter blades in October and back to "regular" blades in April. I live in a VERY snowy part of NY State though
rspi
Jan 11, 2014 06:22 PM
ronananda
Dec 30, 2012 10:00 PM
Dr.JellyFinger
Dec 17, 2011 02:39 PM
95pimpwagon
Jan 20, 2006 01:09 PM
Mr. T
Jan 30, 2005 03:17 PM
