changing the tranny fluid on my 1996 850 turbo
Old 05-23-2006 | 11:53 PM
KINGI5T850's Avatar
Default changing the tranny fluid on my 1996 850 turbo
I was just wonering if it is good or bad to change the tranny fluid it has close to 200000 miles on it. I have heard that is bad but I dont know??? What do you guy's think.thanks. and I was also wondering about a boost controller to are they helpful to get more boost?? and where can i get one? what do you guy think about a underdrive pully?
Old 05-24-2006 | 12:22 AM
rp850's Avatar
Default RE: changing the tranny fluid on my 1996 850 turbo
How does the fluid look? Is it black and burnt smelling? At 200K I'm not sure I'd want to mess with anything. I'd certainly not be looking for more boost unless I was confident the engine was in tip top shape form a mechanical and maintenance perspective. But that's just me.
Old 05-25-2006 | 01:09 AM
Psaboic's Avatar
Concur... Check the color of the trans fluid. It should be clear and red to slightly pink. I have a 95 850 Turbo that had 170K on it when I got it and the fluid looked the color of used motor oil!!![:'(] It took me 18 quarts and several fill/drain cycles, but I finally got it so it now has clean fluid. Tranny shifts MUCH better now.
So, in my humble opinion......Change it!
Old 05-25-2006 | 02:16 AM
rp850's Avatar
I changed mine at 132K and so far so good. FWIW, I went the drain and refill route too rather than a flush.
Old 05-25-2006 | 02:03 PM
fast850r's Avatar
I have a 95 850 T5-R. Just had some work done at local dealer. They suggest flushing tranny fluid every 25000-30000 miles. He said the tranny will last forever. It's $195. A guy at work just had his 93 850 tranny fkushed and he said it shifts much better now.
Old 05-25-2006 | 02:17 PM
robert213's Avatar
At 200K miles, it will be black. I would not power flush, in fear that debris will break loose and cause problems.
Here are procedures that I used to drain and fill...
https://volvoforums.com/m_25657/tm.htm
Old 05-31-2006 | 12:02 AM
SDozier's Avatar
I have a 95 Volvo 850 Turbo that I purchased in 2001. I had the transmission flushed and since then I have had it drained and refilled every two years. Transmission is tight. I would definitely have it flushed if you plan to keep the car.
Chebucto
12-14-2012 02:23 AM
rahaac
10-21-2009 10:51 AM
Trace
05-30-2009 03:32 PM
aruizdelhoyo
01-22-2009 05:46 PM
dpm2340
09-21-2006 09:33 PM
