Check engine light
Old Mar 5, 2007 | 03:55 PM
kakins's Avatar
Default Check engine light
My check engine light is on, myquestion would be is there a way to turn this off or reset this function without the OBDII tool. I just got the codes from autozone my thought was that it would cut off after the code was read unfortunally I was wrong.Help
Old Mar 5, 2007 | 05:52 PM
JPN's Avatar
JPN
Default RE: Check engine light
Hi Kakins,
If your 850 is of '93-'95, yes you can reset the codes + CEL via OBD-I in the engine compartment. Haynes has an instruction as to how to reset it, and there seem to be a few on-line instructions as well. If your 850 is of '96-'97, I believe you will need a decent OBD-II scanner to reset it.
I hope this helps.
JPN
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
