Check engine light
Old Mar 7, 2007 | 02:27 PM
kakins's Avatar
Default Check engine light
Is it true if I disconnect the battery this will turn off my check engine light? I already found out what that I had a miss fire now I just need to get a tune up but that damn light bothers me.
Old Mar 7, 2007 | 06:10 PM
JimKW's Avatar
Default RE: Check engine light
I don't think it will, but you can try it. Make sure you have the code for the radio though. If the car is newer than 95, you need an ODB-II scanner to reset the code. Older than 95 it's done through a port under the hood. On 95's it's a split year where some were ODB-II and some were ODB-I.
Old Mar 7, 2007 | 07:38 PM
JPN's Avatar
JPN
Hi Kakins,
It depends. Sometimes yes disconnecting the battery for 15 minutes or longer deletes CEL, while other times it doesn't.
If you haven't noticed any driveability problem, most likely it's faulty O2 sensor. Tranny-related problems also turn CEL on (on Automatic only).
As Jim has noted, if your 850 is '96 or newer, you need an OBD-II scanner, but if it's '95 or earlier you can manually retrieve codes & delete them via OBD-I.
Good luck,
JPN
Old Mar 7, 2007 | 10:48 PM
RedTurbo850's Avatar
Disconnecting the battery WILL reset all your codes.
However, if there is a problem, the code will come right back.
Old Mar 8, 2007 | 11:54 AM
kakins's Avatar
Got the light off for now friend came by with his ODBII and read it for me also told me it was a miss fire and I should get new spark plugs and wires. What kind of plugs should I get?
Old Mar 8, 2007 | 11:05 PM
OEM. And if you have turbo, maybe the expensive plugs (although they don't add HP, they burn hotter which reduces carbon buildup)
Old Mar 14, 2007 | 10:53 AM
JPN's Avatar
JPN
Greetings from Yokohama, Japan.
I would use either of the following:
1. Genuine Volvo
2. Bosch Platinum +2 or +4
3. Champion (indicated in Haynes)
Any of the following should give you top performance.
JPN
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
