Check Engine light
Old Apr 28, 2008 | 07:26 AM
Dainos's Avatar
Default Check Engine light
My check engine light came on this morning. I may have put too much oil in the engine whre I was topping it up.Could that be a possible cause?
Old Apr 28, 2008 | 08:30 AM
Psaboic's Avatar
Default RE: Check Engine light
I do not think that too much oil would cause the light to come on, but I suppose anything is possible. I would read the codes to seee what caused the check engine light to come on. After you do, please post here so we can help.
Glenn
Old Apr 28, 2008 | 05:29 PM
Dainos's Avatar
I got two error codes 2-4-1 Egr Malfunction and 4-1-4 turbo boost reguation. What do these mean?
Old Apr 28, 2008 | 06:41 PM
241 is usually clogged EGR.
414 might be a bad vaccum line from the EBC (Electronic Boost Controller)
Old Apr 28, 2008 | 07:30 PM
Dainos's Avatar
Ok Thanks.So how does one unclog an EGR?Does any have a part number or a diagram of a EBC?How expensive is this to fix?
Old Apr 28, 2008 | 09:05 PM
You would need to remove the intake and EGR valve and clean it to fix that problem.
The EBC is mounted to the side of the air box. It is a Valve with 3 vaccum lines. Check all the lines really good.
Old Apr 29, 2008 | 08:41 AM
Psaboic's Avatar
Just wondering....is there a way to test the EBC itself, or is it just a replace only thing
Old Apr 29, 2008 | 02:00 PM
Dainos's Avatar
Still would not mind getting a part number and/or pic of the EBC Vaccum lines
Old Apr 29, 2008 | 07:17 PM
Not really an easy test you would need a hand held that would read realtime on it.
But if for Temp only 1 to 2 runs you could bypass and see if you made boost then would be an easy test.
I will see if I can find a pic.
There should be a diagram of the vaccum lines under the hood.
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
