Check engine light
Old Jul 7, 2008 | 10:16 PM
breeze's Avatar
Default Check engine light
Help with 94 850 turbo??? Check engine light will reset for a few miles and come back. The code keeps pointing to bad knock sensors but I replaced the sensors and wires and still have the light. I followed the instructions to check all wires to the ECM and found no problems with wires. Is my ECM bad?
Old Jul 8, 2008 | 08:33 AM
Psaboic's Avatar
Default RE: Check engine light
Possible but unlikely. How does the car run?What I would try next is this....disconnect the battery and remove the ECM. Clean the ECM connector with some alcohol and a soft brush and let it dry. Re-install the ECM, connect the battery, clear the codes again and see what happens.
Old Jul 8, 2008 | 05:49 PM
I had one that had a bad ECM.
Once the new one was in there all was fine.
Old Jul 8, 2008 | 09:55 PM
breeze's Avatar
The car runs good at all speeds. I'll try cleaning the contacts and see what happens.
Thanks for your advise.
Old Jul 9, 2008 | 08:44 AM
Psaboic's Avatar
If cleaning the contacts doesn't work, then I definitely would defer to Tech's advice. He is by far the expert and will not steer you wrong
Old Jul 9, 2008 | 09:20 PM
sporky's Avatar
[align=left]Just a thought...before shelling out big bucks for a new ECM or upgrade, call the guys at Tom's Foreign Auto Parts and ask if they have a used ECM for your car. You can find their shop on Ebay. I've used them and am very pleased with the service and prices. WAY cheaper than my local salvage yards.
[/align]
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
