check engine light
Old Sep 23, 2006 | 06:24 PM
Ron's Avatar
Ron
Default check engine light
I own a '97 Volvo 850 GLT Turbo stationwagon. Yesterday the check engine light came on. i have checked all fluids and everything is at proper levels. and everything else appears fine also. I am not sure what might be causing this light to come on. any ideas anyone. thanks for the feedback.
Old Sep 23, 2006 | 07:40 PM
Default RE: check engine light
You need to get the codes pulled.
If you are in the U.S. try either Advanced auto parts ot Auto Zone they will pull codes for you.
Old Sep 26, 2006 | 01:19 AM
daver80's Avatar
My 89 240GL has the CE light on too, could Autozone "pull a code" on mine too? What's involved? Thank You!! Dave
Old Sep 26, 2006 | 08:29 PM
I don't think Auto Zone knows how to do your you can do it your self.
Follow instructions in the link.
http://www.troublecodes.net/Volvo/
Old Sep 28, 2006 | 12:52 PM
daver80's Avatar
Tech- I learned how to check the codes with the
> little box in the engine bay. In fuel codes I'm coming up with:
> #231- Heated Oxygen sensor-lean mixture, or Lambdfa
> adjustment(?)
#221- Heated Oxygen sensor- rich
> mixture/part throttle
> and
#113- fuel injectors.
> Ignition codes- no faults.
> It looks like a pretty involved procedure to test the Oxygen sensor,
> would you suspect this might be my problem with the light. If the O2
> sensor is bad, I would probably fail an inspection, Yes
Thanks!! Dave
Old Sep 29, 2006 | 09:22 PM
Yes it will fail inspection.
To test the sensor take a Volt meter and hook the black wire up to ground.
Then locate the plug for the o2 sensor there is a spade connector with a rubber boot looking thing over it.
Pull the boot back and connect the positive lead to it. Start up the car and watch the meter it should sweep up and down good. If not first replace the o2 sensor.
Old Oct 4, 2006 | 03:14 PM
daver80's Avatar
Thanks, Tech, I will do it! Dave
tngreg
Sep 5, 2022 07:27 PM
ErnstlS90
Oct 23, 2008 08:37 AM
mstrplmber
Aug 28, 2008 03:34 PM
BRB
Feb 9, 2008 12:29 AM
llama_of_doom
Aug 23, 2007 09:52 PM
