Check engine light wont rest help
I just replaced spark plug wires, Rotor and cap on 1995 850 turbo. there was no check engine light before i changed out. I did manage to put the wires on the wrong position and then started. Finally figured out what I did wrong and now check engine light comes on
Car runs fine now but I cannot clear the code. I tried the A-7 reset and nothing. Iam trying the battery disconnect now for 20 minutes and pulling the modules. I will try again. Any other thoughts.
thx
thx
Drive it down to a parts store and use their scanner to read the code(s) and then reset them to clear the light.
That way if it comes back on you can see if the code is the same, if it is then you know you have a problem.
justinelam13
1998-2000 model year V70
Jul 8, 2012 01:03 PM
ErnstlS90
Oct 23, 2008 08:37 AM
