Checking Flywheel
Old Mar 23, 2010 | 08:34 AM
brianb's Avatar
Default Checking Flywheel
Hey guys...Is there a way to check the flywheel on our cars without removing the engine? I think I may have a couple broken teeth
Old Mar 23, 2010 | 07:14 PM
You can remove the starter and look or check from under the car back side of the motor. There is a small slot where you can see it.
Old Mar 24, 2010 | 09:30 AM
brianb's Avatar
Thanx!
Old Mar 27, 2010 | 12:58 PM
brianb's Avatar
Just did it to and was able see and turn it with a screwdriver after removing the starter. Fortunately, all the teeth were there and the problem was definately the starter.
Old Mar 27, 2010 | 01:00 PM
Well atleast you do not need to remove the tranny and replace the flywheel.
Old Mar 27, 2010 | 01:06 PM
brianb's Avatar
Yep, got a quote for $1035 to have it done if it was the probelm
silly2bme
Apr 27, 2008 11:21 AM
silly2bme
Apr 22, 2008 08:05 AM
brownnb
Jun 11, 2007 10:59 PM
brownnb
Jun 11, 2007 05:09 AM
ProMischiefMaker
Sep 29, 2006 09:16 PM
