Clicking Sound
Old Mar 17, 2009 | 06:13 PM
Chebucto's Avatar
Default Clicking Sound
The 95 850 I bought is pretty much my first front wheel drive car ive owned. Ive had a outer CV joint ripped boot since I bought the car in Dec. Now the famous clicking sound has started, but when I talked to my Volvo Mech, he says it should only make that sound when the car is in motion. I get the clicking noise only once in a while when the car is in motion, but if I stop and put it in park, I can turn the wheels with no noise at all, but if I put it in drive and hold the brake, then turn the wheel, its there. My mech says it should not make the clicking noise when NOT in motion. Is this true, or could it be something else other than the outer CV joint....it seems the ripped boot would be a dead give away.
Thanks
Chebucto
Old Mar 18, 2009 | 07:08 AM
JPN's Avatar
JPN
I would just replace the entire axle; I have not found a replacement CV-joint alone except at the dealer. Beware of cheapo axle assembly; go with a name-brand's product.
JPN
Old Mar 19, 2009 | 08:20 PM
Chebucto's Avatar
Thanks JPN, will do, any brand name better than others when it comes to volvo parts?
chebucto
Old Mar 19, 2009 | 09:27 PM
JPN's Avatar
JPN
Here are some samples:
FCP Groton
TURBO:
http://www.fcpgroton.com/category-ex...137/by_year/45
N/A (may be of the same part as turbo):
http://www.fcpgroton.com/category-ex...136/by_year/45
eEuroparts:
TURBO:
http://www.eeuroparts.com/Main/PartsResults.aspx
N/A:
I believe the brand FCP Groton sells is also Empi.
IPD:
http://www.ipdusa.com/Volvo-850/Tran...p-72-152-2204/
Note, that certain models are fitted with non-reusable hub nut, which has a stake-tab (may be re-usable but I bought a new nut since it was mere $8).
Most of the time, a failing CV-joint makes the popular click at slow turns but since your boot is shot, the joint has probably suffered damage unless you caught it in its earliest stage.
See what other members have to say on the quality of Empi axle. I believe they are good. Check with FCP Groton to see if theirs is also Empi, then you can save a few dollars.
JPN
geealan
Feb 13, 2008 05:07 PM
GRHMB
Nov 15, 2007 08:53 PM
Bobd207s
Oct 24, 2006 11:55 PM
elbert
Apr 12, 2006 10:04 PM
danrashba
Jul 27, 2005 10:06 PM
