clicking marble like sound from rear of 02 s-60 awd
Old Oct 24, 2006 | 12:20 AM
Bobd207s's Avatar
Default clicking marble like sound from rear of 02 s-60 awd
Hi
I just got this car and I'm getting a sound from the rear of the car that is intermittant but it sounds like marbles clicking - any idea what this might be ?
TIA
Bob
Old Oct 24, 2006 | 10:14 AM
adub96's Avatar
Default RE: clicking marble like sound from rear of 02 s-60 awd
Is it under deceleration or acceleration only? I had this problem with an audi once turned out to be that the gears were so worn out that there was play in them...
Old Oct 24, 2006 | 12:12 PM
Bobd207s's Avatar
The car only has 40K miles on it. So it's not very old and used. It sounds like it is coming from the muffler, but I don't think it is. It is still under warrantee, but I brought it to the Volvo Dealership and the mechanic said he didn't hear anything. Because the sound goes off and on. Sometimes doesn't make sound, sometimes it does. I just want to make sure its not a big problem so it ends up costing me millions to fix down the road. Any comments? Thanks
Old Oct 24, 2006 | 12:30 PM
lbrockman's Avatar
Could it be more like a rattle? The sway bar end links fail pretty frequently (front or rear - both) and cause a rattle that can intesify as you go over small road irregularities. Your description may be pretty valid in this case..
- Lynn
Old Oct 24, 2006 | 12:48 PM
Bobd207s's Avatar
Sounds just like if you had a couple of marbles in your hand and were rolling them against each other - the sound was happening while the car was in park and not moving - while it was happening it did seem to happen when I put car in gear - but again this is an intermeiitant thing and last nite it was occurring while i was parked and car was running
Old Oct 24, 2006 | 02:34 PM
Bobd207s's Avatar
also the sound seemed to be coming from the end of the muffler or axle area
thanks for the replies Lynn and ADUB96
Old Oct 24, 2006 | 11:55 PM
Ihatespeedbumps's Avatar
If you are really concerned about it, you could request that the volvo technician drive the car for a day or two to see if they could locate the car. We sometimes drive customer vehicles home for weird/intermittant problems that we can't verify within a standard diagnosis.
geealan
Feb 13, 2008 05:07 PM
GRHMB
Nov 15, 2007 08:53 PM
thejman
Jun 7, 2006 11:49 PM
elbert
Apr 12, 2006 10:04 PM
danrashba
Jul 27, 2005 10:06 PM
