Climate Control Panel (ECC) question...
So I'm new to Volvos but the other day I noticed that the recycle and a/c buttons flash seventeen times before turning off.
Any ideas what this could mean?
Thanks in advance!
Thanks in advance!
put some freon in (if the ac does not blow cold).
"If it blows cold and you have flashing still, don't worry it's common on these cars." The dealer gave me that answer when I just bought my T5 so I went and got freon and the flashes occur little to no more.
Thanks I think that may be the problem since my AC doesnt blow cold at all..
My 850 is a 96
My car started this today. It blinked 17 times. I will check the pressure in the freon system when I find my gauge. Everything seems to work as of now. Anyone has up-to-date experience with this?
If the lights flash when the car is first started it's because the system has found a fault. It doesn't necessarily mean you need to add freon. If you have a 93-95 you should have a diagnostic panel under the hood over by the fill neck for the windshield washer bottle. The first thing to do is read the codes since this will tell you what the system is seeing as a problem.
I don't know if the system knows to set a code for low freon but if you look at the list of codes it could be anything from the temperature sensors with the little fan that is built into the grab handle above the driver or passenger seats or one of the blend doors not responding properly to its signal or one of the temperature sensors in the ducting that has failed. I have a couple of these codes.
Not sure if this is a complete list.
B1 Electronic climate control
111
No fault
121
Outside temperature sensor shorted to ground
122
Outside temperature sensor open circuit or shorted to 12 volts
123
Driver’s side interior temperature sensor shorted to ground
124
Driver’s side interior temperature sensor open circuit or
shorted to 12 volts
125
Passenger’s side interior temperature sensor shorted to
ground(earth)
126
Passenger’s side interior temperature sensor open circuit or
shorted to 12 volts
131
Driver’s side air duct temperature sensor shorted to
ground(earth)
132
Driver’s side air duct temperature sensor open circuit or
shorted to 12 volts
133
Passenger’s side air duct temperature sensor shorted to
ground(earth)
134
Passenger’s side air duct temperature sensor open circuit or
shorted to 12 volts
135
No signal from engine coolant temperature sensor
141
Faulty signal from driver’s side temperature selector switch
143
Faulty signal from passenger’s side temperature selector
switch
145
Faulty signal from function selector switch
151
Signal from fan speed sensor missing or too high
152
Signal from fan speed sensor shorted to earth
211
Driver’s side damper motor position sensor open circuit or
shorted to 12 volts
212
Driver’s side damper motor position sensor shorted to earth
221
Passenger’s side damper motor position sensor open circuit or
shorted to 12 volts
222
Passenger’s side damper motor position sensor shorted to earth
231
Ventilation damper motor position sensor open circuit or
shorted to 12 volts
232
Ventilation damper motor position sensor shorted to earth
233
Floor/defrost damper motor position sensor open circuit or
shorted to 12 volts
234
Floor/defrost damper motor position sensor shorted to earth
235
Recirculation damper motor position sensor open circuit or
shorted to 12 volts
236
Recirculation damper motor position sensor shorted to earth
311
Driver’s side damper motor shorted to earth or shorted to 12
volts
312
Passenger’s side damper motor shorted to earth or shorted to
12 volts
313
Ventilation damper motor shorted to earth or shorted to 12
volts
314
Floor/defrost damper motor shorted to earth or shorted to 12
volts
315
Recirculation damper motor shorted to earth or shorted to 12
volts
321
Driver’s side damper motor active too long
322
Passenger’s side damper motor active too long
323
Ventilation damper motor active too long
324
Floor/defrost damper motor active too long
325
Recirculation damper motor active too long
411
Blower fan seized or drawing excessive current
412
Driver’s side interior temperature sensor inlet fan shorted to
earth
413
No control voltage at driver’s side interior temperature
sensor inlet fan
414
Driver’s side interior temperature sensor inlet fan seized
415
Passenger’s side interior temperature sensor inlet fan shorted
to earth
416
No control voltage at passenger’s side interior temperature
sensor inlet fan
417
Passenger’s side interior temperature inlet fan seized
418
No control signal to blower fan power stage
419
Faulty diagnostic signal from blower fan power stage
420
ECU fault in program memory
511
Damper motor limit position self-adjustment not carried out
Yes, there are plenty of them. You can use any search engine (Bing, Yahoo, Google ...) to get a description. Just type in the trouble code. Once you've done that and it says .... , then you use some of that language or the parts name to search some more. You might also be able to search this forum (volvoforums), Volvospeed, volvoforum, turbobricks ... for a thread on any of the trouble codes.
It's likely you don't have a brand new code no one has ever had before so there should be threads that apply.
You could also post them and have someone here point you in the right direction. I like to give people the tools to find out and I think most of the folks here respect someone who's at least made an effort to find information.
SS760TI
Mar 26, 2007 07:26 PM
